Variable offsets in Onshape vs Fusion 360
robert_blackburn089
Member Posts: 2 ✭
Morning all,
I am trying to migrate myself away from FS360 to Onshape.
I have built myself a CNC by V1 Engineering and when I make a plywood item that has tabs in it in Fusion I can apply an offset to the side of the cut slot in the target piece of say 0.7mm. I can do that for all the slots in the design and vary that. Reason being that the machine is not a $25k setup with wafer thin tolerances.
I can't seem to find a way to do it in Onshape. I can offset the face by a variable but it leaves a second face sort of? It does not push back the surface to allow room for the easier fitting together of the tab/slot in the finished item.
What am I missing here?
Here is a picture of what I get in Onshape when I offset face.
@robert_blackburn089 ,
Are you familiar with the CF's https://cad.onshape.com/documents/578830e4e4b0e65410f9c34e/v/64dbc32dae444548a578ff56/e/7af109b2f1cead90850525ae and/or https://cad.onshape.com/documents/57612867e4b018f59e4d52ce/v/7ce25354b482e8c297780305/e/29340b9ea8177088647ffe75?
One of them can do the job for you.0
