Removing material
in General
I am new to onshape. How do remove material from one angled surface through the solid and to another angled surface? Here is the link: https://cad.onshape.com/documents/cf909c64585cd87537047523/w/94f5c39a9b39e9a7d48bb04a/e/8d84d24fc252eae09e2946a4
Thanks in advance.
Thanks in advance.
Are you looking for something ROUGHLY along these lines ?
https://cad.onshape.com/documents/ae802f875d261332a9f97e0c/w/dd66bea20e7a92b9c402f9af/e/76944da95805a6c1fd1e4010
using a sketch and extrude set to remove
Now there is such a thing regarding the direction that an extrude will or can take
The default extrude tool extrudes in a direction that is NORMAL TO your sketche’s plane, and that’s why your part has that portion left In the top right hand corner
There are extrude featurescripts that allow you to set a direction for your extrude
Here’s an extrude where a segment was used to set the direction
https://cad.onshape.com/documents/bcaa1106bf737b5992d001fa/w/5dc9fe653dae1619141584c0/e/139404dd5308aa9abd31b96d
This part was made with ONE SKETCH on the top plane, followed by seven extrudes
All but the 1st and 4th extrudes, used the SECOND END POSITION ability of the extrude tool, in order to get things positioned at various elevations (Z heights)
https://cad.onshape.com/documents/c00f49af5639c9448db22b5c/w/a03660d08e12926b240993b8/e/af3e272ab3c852746f81b749
@robert_scott_jr_
Your thanks is appreciated
It was a pleasure to do
