Cutting out backing
joseph_newcomer
joseph_newcomer Member Posts: 101 ✭✭✭
edited August 2022 in Community Support
I have a picture frame that looks like this:
What I need to do is get a part that represents the "backing".  It would be exactly the shape of the outside perimeter of this frame.  But it has to be generated from the actual drawing; the designer may yet tweak various parameters of the curves or angles of the corner stones.  The shapes of the corner stones and the curved sides will be cut with a CNC router from a simulated-stone material; the backing will be 3/16" steel or aluminum plate, cut by a CNC plasma cutter.  So I need a part description I can send to the plasma cutter (its software accepts a variety of drawing formats from which it generates the G-codes).  I tried the Boolean operator, but it can't work if the parts don't intersect, which they don't.  The backing will be a solid piece, and the black shapes near the corners are where that backing (which the designer will paint black) shows through.  To get it, I just put a rectangular piece on the back, but we need a piece exactly the shape of the outline that follows the outline parametrically.
    NeilCooke Moderator, Onshape Employees Posts: 6,115 image
    Try the “Use” command in Sketch.
