Cantilever clamp vid turorial, stuck!
daniel_chow
daniel_chow Posts: 108 ✭✭✭
Hello everyone,
I'm stuck on the cantilever clamp tutorial at 1:23.
Here is the link to my document (public viewing)
I can't seem to extrude the smaller cantilever arm. You can see where the red arrow is, it won't let me form a solid shape. What am I doing wrong that it won't let me extrude it?
THank you in advance!
  • andrew_troup
    andrew_troup Posts: 1,585 ✭✭✭✭✭
    I've had a look at your model, and the problem is flagged by a tiny sliver of daylight where my added arrow is pointing. (Zoom in to see it clearly)
    If you carefully inspect the geometry of the first sketch, you will see there is a mismatch between two straight lines and two arcs.
    This can be fixed by recreating the straight lines so their endpoints are coincident with the arcs, and tangent to them.
    It also falls short of best practice (in that first sketch) that it is not fully constrained:
    For robustness, sketches should all go black before you use them as the basis for further modelling
  • daniel_chow
    Thank you Andrew for your prompt and detailed response! On your advice, I took a closer look and extruded the areas excluding the areas marked with the dash, this is what I got:
    ANd zooming in on the area, I found a conflict...
  • daniel_chow
    Fixed it, thank you!
