Assign unique part numbers to different instances of configured parts in assemblies.
I am working on a large project with hundreds of parts and I have decided to break it up into sub-assemblies in separate documents. I have also created a document for "Global Parts" parts used in multiple sub-assemblies. One of the "Global Parts" is a guide rail for a conveyor, an off the shelf part that gets cut to length. I decided to make this a configured part driven by a configuration variable. I then import this part into one of my sub-assemblies and drive its length with a configuration variable in the assembly. My issue is that the part properties remain the same as what I set up in the configured part, I need the part name and number to update to something that makes sense for that assembly, I cant have two parts with different lengths share a part number. Also, because I am pulling from one document into another I need to version the document with the configured rail and cannot easily go and change the part properties without creating a new version.
I set up an example document to show the problem. I hope what I'm describing makes sense.
https://cad.onshape.com/documents/2956d0b5e8ba2adfafa2f7d8/w/2871b7fe0e9e1395294edeed/e/4ea5a67c0392af95336aebe6
Is there a way to prompt the user to enter part properties when importing a part into an assembly? Or perhaps a way to drive part properties with logic?
I am also open to any suggestions for alternate approaches to this problem, I'm sure there are solutions I'm not thinking of or not aware exist.
Thank you all.
Thank you all.
I dont think you can do it when the part is configured at the assembly level, it needs to be done in the part document for each configuration.
If you have a length driving variable, you need to make a row for each length.
It might be possible to automate with featurescript, setting the part number property with a configurable variable.
Its definitely possible to automate it (from an assembly) with the API.
