Exporting all configurations to STL
Hello,
I've seen a few posts asking about this, but they were old and since then OnShape has improved a lot, so I wanted to know whether I'm missing something.
I've designed a pipe bracket in OnShape and it has a few configuration variables (pipe diameter, bracket length). I'd like to be able to export all combinations to STL, like:
  • 10mm pipe diameter, 10mm bracket length
  • 11mm pipe diameter, 10mm bracket length
  • 12mm pipe diameter, 10mm bracket length
  • 10mm pipe diameter, 11mm bracket length
  • 11mm pipe diameter, 11mm bracket length
  • 12mm pipe diameter, 11mm bracket length
  • 10mm pipe diameter, 12mm bracket length
  • 11mm pipe diameter, 12mm bracket length
  • 12mm pipe diameter, 12mm bracket length
How should I go about doing this? Should I use release management? Should I write a script (I'm a coder, but I'm new to OnShape)?
My apologies if I'm using the wrong vocabulary. I only started to use OnShape a few hours ago and CAD is not my main profession, just a hobby.
  • cameron_wellercameron_weller Member Posts: 2 EDU
    I have been wanting to do something exactly like this but from other discussions it doesnt seem that has been implemented yet.
