Figuring out how to make pipes intersect properly.
Hello all,
I am attempting to figure out how to remove the exposed parts of the side pipes inside the main larger tube. (Image below)
https://cad.onshape.com/documents/87a9c28840352a9c7072260b/w/74fa444ae8d00c874c0c01fe/e/3b92ca4084ccd6cc75af390a?renderMode=0&uiState=632077d7e13313077b9b511e
I have tried many different solutions, like booleans, and extruding a sketch through the inside of the main tube with the "remove" setting turned on. Not really sure how to get a clean miter between the two. Any help would be greatly appreciated. Thank you.
