Limitation offset sketch command
carl_larssoncarl_larsson Member Posts: 5 ✭✭
The offset command is acting strange. Why is the offset command ignoring the two small tangential arcs here? What's its limitations?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,991 image
    If you dragged it to the point where the arcs disappeared then changed the offset dim to be small again, the arcs will not reappear.
