Move Variable/s from Part Studio to Variable Studio?
matthew_stacymatthew_stacy Member Posts: 489 PRO
Is it possible to move an individual variable, or variable table, from Part-Studio to Variable-Studio?  If so, how?
  • matthew_stacymatthew_stacy Member Posts: 489 PRO
    I had the "copy", but it was executing the "paste" operation that had me flummoxed.  Thanks for the tip @_anton!  Worked like a charm.
  • joel_bruxvoort355joel_bruxvoort355 Member Posts: 3 EDU
    As described above I tried to copy a table (multiple variables) using the three dot menu (from a part studio). When it pastes (ctrl-v) into a name cell in a variable studio !!all of the text remains in the name cell!!.  This is using Chrome on a PC.
    The table pastes into multiple cells (columns and rows) in Google Sheets but does not paste correctly in a variable studio.
    Any thoughts?
  • _anton_anton Member, Onshape Employees Posts: 526 image
    @joel_bruxvoort355
    You'll need to make a variable in the Variable Studio first, then single-click its name cell (such that you're not editing the name), then paste. That's the way our table paste works right now.
  • fernando_dominguesfernando_domingues Member Posts: 3
    aaa_anton said:
    @joel_bruxvoort355
    Man.... That way it works is dumb to say the least. It looks like it should never work doing it that way... We should be able to click 1 button to paste, preferably in the 3 dots menu of a Variable Studio.
    How it works is, you open the variable studio, then create a variable with whatever name, save it, and then, after it is created, you click on that single var and paste...
    @fernando_domingues I agree that it could be better. :smile:
    Feel free to write an improvement request; it helps us prioritize things.
  • S1monS1mon Member Posts: 4,061 PRO
    I haven’t tried this with Variable studios, but it sounds much like how paste works in Configuration tables. It took me a while to get the hang of it, and it’s not super discoverable, but it does work.
  • John_StutzJohn_Stutz Member Posts: 4 EDU
    Perhaps I'm missing something, but the pasted value in the variable studio does not update when the value in the variable table changes?
  • pavel_lelyukhpavel_lelyukh Member Posts: 8
    There nothing more stupid than having a variable table, a variable studio and not having a one click export button to convert a variable table into a studio instantly. Who the hell managed that project.
    You're literally wasting hours of thousands of peoples time
  • es_doubleues_doubleu Member Posts: 4
    For anyone like me that just got to this thread and is still confused on how exactly to transfer a part studio variable table to a new variable studio, here's my attempt at a helpful recap.
    1. Click 3 dots on part variable table -> Click copy table
    2. Create variable studio or go to existing variable studio
    {wonky part!}
    3. Click the name... cell and type whatever silly name you want (press enter)
    4. Now left click on the silly name
    5. crtl+v/cmd+v
    [bonus!]
    6. Delete the row that has the words name etc.
  • stuart_robinsonstuart_robinson Member Posts: 37 ✭✭
    {wonky part!}
    5. crtl+v/cmd+v
    [bonus!]
    you're a hero @es_doubleu thank you so much for spelling this out!!!!  worked amazingly for me. what a relief
    @_anton a simple tooltip in the app could basically solve this.  also it looks like this is wrong as @es_doubleu thankfully discovered: https://cad.onshape.com/help/Content/variable_table_assembly.htm#Table-options
    The Copy table command copies them to the clipboard, but data cannot be pasted into them from the clipboard.
  • bob_haroldbob_harold Member Posts: 2
    Ok, next step - how do I delete all the variables from my local table now that they are in the part studio? And please, not one at a time.
  • ding_chending_chen Member Posts: 2
    You can select the variables you need to delete in Features tree in your part studio, then right click on any one of them and select 'delete'.
  • sean_mitchell128sean_mitchell128 Member Posts: 2
    This might be the dumbest thing I have ever seen in my life.
    We should be able to highlight variables in part studio, right click, and copy them to a variable studio.
    This is nothing short of absurd.
