How to check if an edge is a straight line?
eric_pesty
This is probably obvious but I'm struggling with figuring out if something is "straight"...
I'm computing the min radius of curvature of a sweep path and got it working (I stole/repurposed the code from @NeilCooke 's cable/wire routing) but i would like to do a check first so I don't sample curvature a bunch of times if the segment is just a straight line...
I thought I could use "canBeLine" but it seems to always return false even when I pick a straight sketch segment as my input...
    edited September 2022
    I will soon release a new version with better code you can steal :)
  • Alex_Kempen
    Alex_Kempen Member Posts: 258 EDU
    First, some terminology. Edges refer to physical edges in the model space, like those created by the sketch line tool and those that bound the intersection between two faces. In FeatureScript, edges exist solely as queries, which are used internally by Onshape to go into your model and find specific entities.
    Line refers to a FeatureScript data object which defines a mathematical line, e.g. an object with an origin and a direction. canBeLine is a predicate for checking if a given value is a Line object. Lines can be made from queries for edges using evEdgeTangentLine - for a straight line, the choice of parameter shouldn't matter too much, although the location of the origin will change (0.5 for the middle, 0/1 for the start/end, although note that the start and end of edges is generally arbitrary).
    Whether a query contains straight edges can be tested with qGeometry(GeometryType.LINE). Specifically, !isQueryEmpty(context, qGeometry(myQuery, GeometryType.LINE)) returns true if myQuery contains a reference to a straight edge and false otherwise.
            var samples = 1;
            const wireGeometry = evCurveDefinition(context, {
                        "edge" : edge
            if (wireGeometry is Line)
                continue;
            else if (wireGeometry is Circle)
                if (wireGeometry.radius >= minBendRadius)
                    continue;
            else
                samples = floor(evLength(context, {
                                    "entities" : edge
                                }) / (minBendRadius / 4));
            const curveSamples = @evEdgeCurvatures(context, {
                        "edge" : edge,
                        "parameters" : samples == 1 ? [0.5] : range(0, 1, samples)
    excerpt from changed code
  • eric_pesty
    Thanks @Alex_Kempen, I think this is what I'm after. I'm trying to avoid doing "excessive" evEdgeTangentLine.
  • eric_pesty
    @NeilCooke
    I need to study this more but it looks like exactly what I need to do, I'll take a look when I get a chance! I'm assuming the "circle" case will detect a circular arc?
    This is what I currently have, the key difference being I need an extra loop as I'm looking for the curvature on a path that can have multiple segments:
    export function computeBendRadius(context is Context, OD is ValueWithUnits, path is Query) returns ValueWithUnits
        var minRadius = 1e6;
        var minPoint;
        const edges = evaluateQuery(context, path);
        println("number of segments: " ~ size(edges));
        for (var e = 0; e < size(edges); e += 1)
            var segmentLG = evLength(context, { "entities" : edges[e] });
            var segmentsamples = floor(segmentLG / OD * 3);
            println("segment " ~ e ~ ", Length: " ~ toString(segmentLG) ~ ", samples : " ~ segmentsamples);
            var segcurvesamples = @evEdgeCurvatures(context, {
                    "edge" : edges[e],
                    "parameters" : range(0, 1, segmentsamples)
            for (var sample in segcurvesamples)
                if (minRadius > 1 / sample.curvature)
                    minRadius = 1 / sample.curvature;
                    minPoint = sample.frame;
            println("min radius so far : " ~ minRadius);
            if (isUndefinedOrEmptyString(minPoint))
                minPoint = segcurvesamples[0].frame;
        println("overall min radius: " ~ minRadius);
        minRadius *= meter;
    EDIT: why is the "code" block so dumb in here?
    @eric_pesty that’s a bit hard to read - select the font for “code” first then paste your code into the yellow box.
  • eric_pesty
    @NeilCooke
    I also meant to ask, where does the "length / (min bend / 4)" come from on the number of samples? Is that a "scientific" way to determine how many samples are required or just something that "works"? Just curious!
    In my case I am just trying to find the minimum bend radius and display in a table (rather than establish a pass/fail so I might need to do this a bit differently...). I replaced your min bend radius with the diameter of my sweep but really what I'm looking for is not dependent on what I'm sweeping!
    I should be doing whatever the "curvature comb" is doing to display the min curvature... (and as a side note it would be really nice if we had access to a function that would do that for us as efficiently as possible rather than writing our own!)
    It’s just a number because it only needs to be approximate in my case - I should probably relate it to wire diameter.
  • eric_pesty
        var minPoint;
                    "edge" : edges[e],
        minRadius *= meter;
    Ah ok! Create the "code" section first.
    I had pasted the code first and selected it and formatted as code and that was a disaster (the whole thing was on one line with extra HTML crap), talk about hard to read:
    <div>export function computeBendRadius(context is Context, OD is ValueWithUnits, path is Query) returns ValueWithUnits</div><div>{</div><div>&nbsp; &nbsp; var minRadius = 1e6;</div><div>&nbsp; &nbsp; var minPoint;</div><div><br></div><div>&nbsp; &nbsp; const edges = evaluateQuery(context, path);</div><div><br></div><div>&nbsp; &nbsp; println("number of segments: " ~ size(edges));</div><div><br></div><div>&nbsp; &nbsp; for (var e = 0; e < size(edges); e += 1)</div><div>&nbsp; &nbsp; {</div><div><br></div><div>&nbsp; &nbsp; &nbsp; &nbsp; var segmentLG = evLength(context, { "entities" : edges[e] });</div><div>&nbsp; &nbsp; &nbsp; &nbsp; var segmentsamples = floor(segmentLG / OD * 3);</div><div>&nbsp; &nbsp; &nbsp; &nbsp; println("segment " ~ e ~ ", Length: " ~ toString(segmentLG) ~ ", samples : " ~ segmentsamples);</div><div><br></div><div>&nbsp; &nbsp; &nbsp; &nbsp; var segcurvesamples = @evEdgeCurvatures(context, {</div><div>&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; "edge" : edges[e],</div><div>&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; "parameters" : range(0, 1, segmentsamples)</div><div>&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; });</div><div>&nbsp; &nbsp; &nbsp; &nbsp; for (var sample in segcurvesamples)</div><div>&nbsp; &nbsp; &nbsp; &nbsp; {</div><div>&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; if (minRadius > 1 / sample.curvature)</div><div>&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; {</div><div>&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; minRadius = 1 / sample.curvature;</div><div>&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; minPoint = sample.frame;</div><div>&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; }</div><div><br></div><div>&nbsp; &nbsp; &nbsp; &nbsp; }</div><div>&nbsp; &nbsp; &nbsp; &nbsp; println("min radius so far : " ~ minRadius);</div><div>&nbsp; &nbsp; &nbsp; &nbsp; if (isUndefinedOrEmptyString(minPoint))</div><div>&nbsp; &nbsp; &nbsp; &nbsp; {</div><div>&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; minPoint = segcurvesamples[0].frame;</div><div>&nbsp; &nbsp; &nbsp; &nbsp; }</div><div><br></div><div>&nbsp; &nbsp; }</div><div>&nbsp; &nbsp; println("overall min radius: " ~ minRadius);</div><div>&nbsp; &nbsp; minRadius *= meter;</div>
  • eric_pesty
    Quick update,
    I ran into some difficulties with implementing the code above as I am doing things a bit differently but then I did a "profile" and sampling the curvature 50times on a straight line is quicker than 5 samples on a spline so the performance impact seems pretty negligible.
    Interestingly, adding the debug arrow is quite a bit slower than the curvature sampling loops, and the opSweep are also slower so while it's not super efficient it doesn't really have a noticeable performance impact so I am going to leave it like this for now.
        var minPoint;
        const maxsampledist = .25 * inch;
        //    println("number of segments: " ~ size(edges));
            var sampleint = min(maxsampledist, OD);
            var segmentsamples = floor(segmentLG / sampleint * 3);
            // println("segment " ~ e ~ ", Length: " ~ toString(segmentLG) ~ ", samples : " ~ segmentsamples);
                    "edge" : edges[e],
            //println("min radius so far : " ~ minRadius);
        //println("overall min radius: " ~ minRadius);
        minRadius *= meter;
        //display path and min radius location
        minPoint = coordSystemFromBuiltin(minPoint);
        addDebugEntities(context, path, DebugColor.BLUE);
        if (minRadius < OD / 2)
            addDebugArrow(context, minPoint.origin + minPoint.xAxis * minRadius * 20, minPoint.origin, OD * 2, DebugColor.RED);
        else
            addDebugArrow(context, minPoint.origin + minPoint.xAxis * minRadius, minPoint.origin, OD, DebugColor.GREEN);
        return minRadius;
