Variables inside variables with math
weston_koffordweston_kofford Member Posts: 5 EDU
so I am modeling a bottle but I want to be able to change a few numbers and end up with a smaller or bigger bottle
I'm using the pithagriam therum to get a wall and have this and both of these variables are assigned
BottleDim=30mm
BottleNeckHeight=80
BottleSideAngle=((BottleDim/2)^2+BottleNeckHeight^2)
Can someone explain why this doesn't work? if you need more info tell me and I can get it and update the post
    BottleDim has units, Height does not. BottleDim^2 is an area not a length. Balance out the units or remove them altogether.
  • weston_koffordweston_kofford Member Posts: 5 EDU
    Sorry that was a miss type it does have units and I'm performing an equation to find a length...
    BottleDim=30mm
    BottleNeckHeight=80mm
    BottleSideAngle=sqrt((#BottleDim/2)^2 + #BottleNeckHeight^2)
  • Nath_McCNath_McC Member Posts: 136 PRO
    edited October 2022
    Removed the comment as I missed Neil's solution.
