Sketch Dimensions in BOM
troy_ostrander
Member Posts: 31 ✭✭
Hello OS Community,
Is it possible to link sketch dimensions of a subassembly into a BOM? See attached mockup image.
NeilCooke
Moderator, Onshape Employees Posts: 5,933
Only with computed part properties, which requires Pro or Enterprise.Senior Director, Technical Services, EMEA0 -
EvanReese
Member, Mentor Posts: 2,695 PRO
If you aren't on Pro and able to use computed properties, you could use FeatureScript to hijack an existing property, like "Description" or "Title_1" with a custom feature to show them. Here's an example.
https://cad.onshape.com/documents/4e51452ff70b3ad0eec3834a/w/4dd316799a1900ab58bc1e38/e/a4bd5d3b9ab5c1ff60232754
Here are the basic steps:- set the values as variables
- make a feature that calls those variables, and converts them to a readable format (i.e. rounding them, removing the units, adding other text like "Length" etc)
- insert the feature after the part is created and select it.
1
I don't know your comfort level with programming, so I may be under-explaining it. Feel free to ask for more info where needed.The Onsherpa | Reach peak Onshape productivity
