New user help on changing length of an object
OnyxiusOnyxius Member Posts: 5
Hello,
 I am trying to figure out the best way to change the distance between the top and bottom (red arrow in pic) of this object.  The object will change in height and the easiest way I can think of doing this without changing the top or bottom of the object, is to somehow just change the middle by cutting and stitching maybe?  I'm still new so there is a lot I have not learned just yet.  So for instance from the bottom yellow dot to the top yellow dot, lets say I need to make that distance 43mm.  Then when I need to change the length between the two to say 49mm, I would change the middle in the yellow square somehow without changing the top half hole and bottom half hole.
Any help is greatly appreciated.
