Flatten out in spring design
matthew_stacy Member Posts: 487 PRO
@frank_ring, you might also try using a projected curve to transition from the helix to the flat coil.I created one sketch, comprised of a single circular arc, to straighten the helix. Then I created a second sketch, again comprised on a single circular arc, but oriented perpendicular to the axis of the helix. Projecting these two curves creates a nice transition from helical coils to the flat coil at the spring.Then create a third sketch to complete the partial flat coil.Does that work for your application?1 -
@frank_ring, try it now. You should be able to view and/or copy that document now.
1
https://cad.onshape.com/documents/12b0679a712bc6f544f72c07/w/67e973d9c8c7d9393a467fa0/e/ad111428e8f3c86c992bfae8
@matthew_stacy is there a way to view the document as a "free plan" user?
