Direct Editing - Rotate
Axel_KollmenterAxel_Kollmenter Member, pcbaevp Posts: 436 PRO
I have designed a clip on a plastic part and now I want to change the position. But now I am too lazy to draw the contour again and want to reposition the clip by the "move face". I have never used the feature for such an action. I have already looked at the tutorial in the Learningcenter, but it doesn't really get me anywhere.
The feature throws an error by itself. In addition, the 90° I want are twisted....
The clips should rotate 90° around the mateconnector and end up sitting at the position where the rectangle is located as a sketch.
Best regards,
Axel Kollmenter
  • sebastian_glanznersebastian_glanzner Member, Developers Posts: 466 PRO
    Can you split the clip from the main part?
    Then you could use Transform to rotate the "Clip body" and use a boolean feature to merge it again.
  • Axel_KollmenterAxel_Kollmenter Member, pcbaevp Posts: 436 PRO
    I think it was because the clip was connected to the outer wall (Coincident) and the cutout to demold was also a problem.
    Best regards,
    Axel Kollmenter
    ouh this would be a good option too. I think this should work too! Thank you
    Best regards,
    Axel Kollmenter
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,501 PRO
    Yes, I was going to suggest doing a body transform instead. The key thing to keep in mind with the "move face" is that it generally can't create or delete faces.
    If you can visualize the operation with just "sliding" things around it should be ok but if anything needs to "jump" it will fail.
