Can you create a linear part pattern with the distance between entities growing or shrinking?
mspiccione
mspiccione Member Posts: 4 EDU
For example, I'm trying to pattern the frets/fret spacing on a guitar and each fret is 1/(2^(1/12))  (about 0.94387) smaller than the next starting at the top of the neck and the first fret is about 1.431 away. the second is 1.3506 away from the first. I tried using variables that built on each other like #fretspace = #fretspace*.94387 with the spacing but when setting the distance as a function in the linear pattern(feature), it sets the variable to number so it doesn't change with each iteration. thanks for the help
