Drawing Font size?
Mark_50Mark_50 Member Posts: 6
is it possible to change the font size on dimensions?
I like to increase the font size on my drawings to compensate for folks that take a "C" size drawing and print it on "A" size paper. I generally use a 20+ something font and call for bold text. This makes the document readable.
Is this possible with Onshape yet?
Thanks
Mark
    This is not yet possible in Onshape.
  • chris_barilchris_baril Member Posts: 1
    I had the same question and got the following response from the very helpful support rep:
    Currently this is set by the template. In the first build of Drawings we are controlling a lot of the settings with the template... Currently you cannot change the template once you pick on but here are some notes to create your own templates:
    We are working on allowing more of this in coming builds.
    @Mark_50 , Currently this facility is not available in onshape. You can raise a ticket and or make an improvement request for this.
  • Mark_50Mark_50 Member Posts: 6
    Thanks. No need to make work for anyone. It is a feature that I find useful, maybe not so much anyone else.
    m
    @Mark_50
    Improvement requests are an invitation for users to vote on how useful they would find a given enhancement, as opposed to feedback tickets which are a private suggestion, so no worries on that score.
    I personally think what you ask for is essential and inevitable, it's just a matter of when it reaches the top of the "To Do" list.
  • jon_mcintyrejon_mcintyre Onshape Employees Posts: 56 image
    We agree that it's essential and inevitable.  It is indeed getting near the top of our list.
  • MaximumMaximum Member Posts: 2
    Any update on this? This is an item of high importance for drawing readability if your drawings are not so standard.
  • john_mcculloughjohn_mccullough Moderator, Onshape Employees Posts: 38 image
    Drawing dimension text size has been adjustable for a while now (Jan 2016). This field can be found at the top of the Properties flyout (accessed from the Properties button on the left end of the drawings toolbar).
