Hollow cavity in solid part not exporting
Hi, all. Fairly new to Onshape and I'm having problem with this rather simple design. It's a simple box in which I want to embed magnets inside when 3D printed. The part looks correct in Onshape. The cavity appears in the translucent view and the sectional view. However, when I export the STL, the cavity is not present. Any ideas? I've linked the part below. The cavity I'm having problems with is the extrusion labeled "Magnet Pocket"
My box design
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,988 image
    Must be your slicer? Exported as STL and imported back in and cavity is there.
  • leonard_cassidyleonard_cassidy Member Posts: 6
    Really? I imported it both Cura and tinkercad and it's not there.
    I exported as "fine" and imported - try it.
    Just check it on SuperSlicer and the cavity isn't showing there either. Is it maybe an export from OnShape setting that I'm missing? Up further investigation when I export as a 3mf everything appears fine. So this makes me think my export to stl settings are off somehow but I'm not sure how.
    I exported as STL and it was ok - maybe your slicer doesn't like internal volumes (if that's a thing)?
  • robert_morrisrobert_morris OS Professional, Developers Posts: 173 PRO
    I just exported the STL and opened it with the latest Cura for Lulzbot, and the it looks like the magnet pockets are there.
    Thanks, all. Not sure what I was doing but it seems to be working as expected now. /shrug.
