Importing to an empty folder
Connor_LeCLaireConnor_LeCLaire Member Posts: 33 ✭✭
Hello,
When trying to import a part or assembly into an empty folder, it imports outside of the folder (even when the folder is selected, right-clicked, and import is selected). Currently I have to create a part studio or assembly in the folder, select the part studio (and make sure I double click to actually open it) then import the desired file and delete the empty part studio/assembly. Is there something I'm missing to streamline that process?
This occurs regardless of the file type (step, parasolid, SolidWorks, etc).
Thanks!
    You are right in what you are saying. I don't know if this is classed as a bug or an improvement request, but if you create a support ticket, they will tell you.
  • Connor_LeCLaireConnor_LeCLaire Member Posts: 33 ✭✭
    Ok will do, thanks!
