Multi-color parts
carokhancarokhan Member Posts: 6 EDU
Is there a way to set the appearance of a part as multi-color? For example, if I have a rectangle extrusion - I want it to be "rainbow" in that one end is red and it blends until the other side is purple. Thanks!
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,952 image
    erm, no, there is no rainbow option.
  • Axel_KollmenterAxel_Kollmenter Member, pcbaevp Posts: 436 PRO
    edited November 2022
    You could import an image of your gradient to the part. But then you cant see it in the assembly. Images are currently only in Parts visible.
    Best regards,
    Axel Kollmenter
  • S1monS1mon Member Posts: 3,860 PRO
    There’s also Render Studio…
