Feature script on tablet
SleepyheadSleepyhead Member Posts: 19 ✭✭
Am I reading this right and that feature scripts, like distance measure, is not a supported on mobile devices. I am only a hobbyist but have been forced off a laptop and onto a tablet.
    edited November 2022
    You can add them to your toolbar and use them (see last icon on the pallette), you just can't edit them.
    Who forced you off the laptop?
  • SleepyheadSleepyhead Member Posts: 19 ✭✭
    Laptop old and Broke. Cancer and a stroke and unable to work have left the wallet a little light and can not make replacing this a top priority, for what some may not consider a large spend, regrettably I do. Currently saving for a good iPad pencil finger getting sore.
    I had already successfully added the “measure distance” feature script along with another couple and other than “MD” Script and successfully used them. I have failed to make any of them work on the iPad. Thought it was me
    I had found that on my modelling where I used arrays ( I think they are called) that I had previously produced on laptop, that this to was no longer available.
    I am sure a few variables and a bit of maths will get me a useable result. I am trying to produce knurling effect but on a flat surface with the surface being able to be of variable size.
    Thank you for your response.
    My son let me use his work laptop where I added what I needed.
    As you said useable once added.
    Are there the same issues on a chromebook
    As you said useable once added the iPad.
