Text extrude cut generation & automation
Nath_McCNath_McC Member Posts: 136 PRO
Hi All,
I have a part file that I want to automate the text generation on it. I would like to have the model for each text example D1.01 to D1.26, D2.01 to D2.26, D3... D4 etc
With over a couple hundred versions, I was hoping somebody knew how to automate the text cutout generation.
Any help would be appreciated.
  • S1monS1mon Member Posts: 4,077 PRO
    See this thread. Also, if you need to generate the pattern of text, it may be easier to do that with a spreadsheet and then paste that into the configuration table to create all the options.
  • Nath_McCNath_McC Member Posts: 136 PRO
    @S1mon Thank you for that! Makes my life a lot easier. So some reason, I didn't think about configurations for some stupid reason.
    Do you know a quick way to export every configuration as an STL in one go?
  • dirk_van_der_vaartdirk_van_der_vaart Member Posts: 561 ✭✭✭
    Yes, in the part studio with your configuration, right click on the generated part and select export as STL, and give exported file the name you wish
  • emagdalenaC2iemagdalenaC2i Member, Developers, Channel partner Posts: 864 ✭✭✭✭✭
    @dirk_van_der_vaartThat exports only the active configuration, but not all
    It is not possible and also I doubt that it is recommended.
    Think that for example, you can define a variable with the length in a configuration, so you would have infinite configurations of these components
    Un saludo,
