Reconstruction of Roman bowl GIMP to Onshape, STL to Ultimaker Cura errors
Total newbie - I need Cura for a Roman pottery project. (I haven't come straight here - I have looked at trying to resolve it myself). I have this Roman first century bowl, a complete profile, and wanted to reconstruct the rest with 3D printing. I measured the pot, drew it in GIMP, imported the image to Onshape, traced over it, thickened and rotated it, saved as an STL. The import process to Cura failed ("The highlighted areas indicate either missing or extraneous surfaces. Fix your model and open it again in Cura." An ideas? And is there any way to show an STL file here
  • EvanReeseEvanReese Member, Mentor Posts: 2,416 ✭✭✭✭✭
    Maybe skip gimp and just make it in Onshape? Not sure what your exact issue is, but the image of Cura looks like it's paper thin, which probably isn't the intent. You might also try just revolving a surface and using Thicken after that.
