Custom feature referencing a geometry generated by another features?
ben_partouch
Member, csevp Posts: 168 PRO
Hello,
Any recommendations for how to code a feature that can identify, for ex. pockets made by a specific extrude, and move translate the faces created by that extrude?
The idea is that instead of heaving to select all these pockets, the custom feature will select all faces (or other geometry) created by a specified feature.
Hopefully that makes sense.
Thank you.
Thank you.
Take a look at Selection fillet from @Evan_Reese for how to create an intelligent parametric selection like that.
Glad it's helpful! I'm sure there are smarter code structures to use, and I'd probably write that differently today, but the ideas should be the same. I also recommend just reading through every single type of query in the standard library documentation to get ideas for the kinds of logic you could use. My feature doesn't do them all.0
