How to define a point on a sketch plane from a line passing through it.
I need to extrude my sketch at an angle that's parallel to another part. I thought I would use a sweep to make that happen. So, I've defined a construction line from that other sketch and I want to define a point where that line passes through my new sketch plane so I can constrain the sketch. I also made a construction line on the current sketch, but coincident isn't working. I've included a screenshot. Thoughts? Thanks!
