Restore vs Versions
florian
Member, OS Professional Posts: 110 ✭✭✭
First post after a lot of good feedback from the support team.
I am missing the possibility to go back to an earlier created version. In git terms:
git checkout <commit> <file>
Yes, it is possible to skip back in history, which is a pretty long list if you just had to undo the last twenty minutes. Technically a version should know at what point in history it was created. Next I was searching for was a "Saved Version" entry in the history => No luck as well. I don't want to branch every time I try something. Or would that be the intended approach?
Any Idea how to easily restore versions? Maybe I'm getting the system wrong…
PS. , @DaVicki has a really nice workaround.
This saved version can be used as a branching point as well.
