Extrusion problem I don't understand
daniel_kukieła
Member Posts: 4 ✭
Hi,
I'm creating 3D-printable Power supply hole cover for PC cases that use the so-called Pico PSU (a hole for it will be added later). For now, I created the base shape and I am configuring options. I added mesh and I'm trying to add back material where the screws are coming in. The problem is extrusion works fine for 1 out of 4 spots only. The spot that it works:
But as soon as I'm trying to add another spot to Extrude 4 (from Shetch 3):
Honestly, I have no idea what it is complaining about. I tried so many things but I decided to ask.
The document URL: https://cad.onshape.com/documents/02e11ac6c38230e5a1618296/w/7d6a0710d7bed4906d5b365c/e/cdcb218ee44614c759821038?configuration=List_XmLQE1L57Tz3hC=Full&renderMode=0&uiState=63d742925336de296233612f
I'll be glad if anyone can explain what's wrong here.
Thank you in advance.
- Daniel
- Daniel
- Daniel
That's not difficult to do in a configuration.
