Replicating a Surface...
![david_murphy384](https://cad.onshape.com/images/placeholder-user.png)
Hello Community - I'm looking for help in the design of a "cupola" for my model railway station. The cupola is octagonal and I have managed to get so far with it. However, I am unsure as to how to get the octagonal "bell-shape" at the top. In my design : InverurieStation_Cupola_Top you will see that I have made a SURFACE for one of the 8 panels.
My question is: How do I replicate it to the other faces?
Or maybe my question should be: Is this the best way to do this or is there a better alternative?
![Image: https://us.v-cdn.net/5022071/uploads/editor/3g/sshfcik9pgcl.jpg](https://us.v-cdn.net/5022071/uploads/editor/3g/sshfcik9pgcl.jpg)
![Image: https://us.v-cdn.net/5022071/uploads/editor/i9/el4ncrk7l5bg.jpg](https://us.v-cdn.net/5022071/uploads/editor/i9/el4ncrk7l5bg.jpg)
Many thanks in advance for your assistance and advice to this 'newbie'.
Evan_Reese Member Posts: 2,071 PRO
you could also just sweep it. If you have a profile curve for the shape, use that as the profile and the octagonal lines as the path. Sweep will handle the mitering. https://cad.onshape.com/documents/2979fe9d1bd93fb15470423b/w/0afe9c7ca05a365c677b8a73/e/945f6630fcfac22e099eb59aEvan Reese / Principal and Industrial Designer with Ovyl
Website: ovyl.io1 -
Actually, looking at that tower more, you could do pretty much the whole thing as a single sweep, then add cutouts for the archways, and model the columns which can both be replicated with a circular pattern.Evan Reese / Principal and Industrial Designer with Ovyl
Website: ovyl.io3 -
The feature list can be pretty durn short
Website: ovyl.io4
You'll just have to select the surface to pattern and the center axis of the pattern, and set the angle to 360deg and instance count to 8.
Website: ovyl.io
Website: ovyl.io
Website: ovyl.io
I did not know sweep could handle an octagon like that. Cool!
CADSharp - We make custom features and integrated Onshape apps! cadsharp.com/featurescripts 💎
Website: ovyl.io
