Can you adjust version description text? Format issue
Ulises_FMUlises_FM Member Posts: 74 PRO
The Versions and History view of a document is very useful to quickly read the descriptions of its versions. However, this happens (see image).
The description is cut due to the width of the Description column. I couldn't get a way to adjust this width. The best solution would be to simply adjust the text to the width of the column (multiline like).
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,862
    The only way to do this now is to click on the gear icon on the right and select properties. But, you are right, it should be better.
  • chadstoltzfuschadstoltzfus Member, Developers, csevp Posts: 156 PRO
    How does one get to see the description in the Versions and History view? For me it only shows the Name and Modified columns.
    chadstoltzfus@premiercb.com
    edited February 2023
    You have to right click the doc in the docs page. The info panel does not include this detail.
  • Ulises_FMUlises_FM Member Posts: 74 PRO
    This isssue has not yet been solved.
