TooTallToby Material new Featurescript
STEG
Member, User Group Leader Posts: 77 PRO
*Texte en français au bas
Hi everyone!
I just created a new version of the FS "TooTallToby Material" where you can see mass in both units (grams and pounds) at once. Now you can change only the length units and skip the mass units change to find the correct mass of your part. You can find it here: https://bit.ly/TTTMaterialBySTEG
All comments are welcome!
Hi everyone!
Bonjour à tous!
Je viens de créer une nouvelle version du FS "TooTallToby Material" où vous pouvez voir la masse dans les deux unités (grammes et livres) à la fois. Vous pouvez maintenant modifier uniquement les unités de longueur et ignorer le changement d'unités de masse pour trouver la masse correcte de votre pièce. Le FS se trouve ici : https://bit.ly/TTTMaterialBySTEG
Vos commentaires sont les bienvenus!
Just one thought, some TTT parts in IPS are small and require more digits of precision (I think I've seen up to x.xxxx lb?).
You could be fancy and add a control to input the number of decimals, that would be neat!
Nice, thanks!
CADSharp - We make custom features and integrated Onshape apps! cadsharp.com/featurescripts 💎
I think the solution is somewhere around here:
tableRow
valueWithUnitAndPrecision
Anyone can help?
Will add a new link when I make sure it works properly which is not the case now! lol
