Pin-slot movement
ricardo_raimondo
Member Posts: 66 ✭✭
I have this flap that I want to have a displacement back and down, with the two pins moving in the curved slots. However, to start my headache, with just one pin with a tangent mate, two things happen: If I fix the slotted part, nothing will move. If I unfix it, then I can displace the pinned part back and forth which makes the other piece to move up and down, but it will not rotate around the pin. I guess for the same reason, when I try to add another tangent mate to the other pin, it shows as fail (red font).
I will appreciate any help.
The link to the document is https://cad.onshape.com/documents/185a0d0f952b54fd8d257124/w/e5d64523a1a8e94d8539ec4f/e/737b66723750621fe8be210c
https://cad.onshape.com/documents/4652089891902cabc4ce288a/w/769c7e386f388aa98514eaca/e/a3b8850437ada595a0a0431c
