Migrating projects from SolidWorks to Onshape: what gets lost and needs fixing by hand
julian_toddjulian_todd Member Posts: 5
I'm trying to move a colleague's project from his years of work based on a single private copy of Solidworks to Onshape so that the rest of the team can engage with it.  He gave me a dump of 120 sldprt and sldasm files in a zip file.  Eventually I got it all imported into Onshape, subject to a few issues which I got immediate help on by posting feedback from the window.
I presume the workflow for moving stuff from Solidworks to Onshape is pretty important, so it would be better for the system to make a few suggestions when such a file fails to import instead of providing a tab with a blank page and just the file name.
There's very little special documentation on this matter other than the paragraph in yellow on this page about the name of the top level assembly file:  https://cad.onshape.com/help/#uploadfiles.htm
Then there's the question of what exactly has been imported.
You know that pointless dialog box you get when you're in Word and you save as rtf?:
"The document may contain text content that will be lost upon conversion to the chosen encoding..... Do you want to continue saving the document?"
This is sad because the file converter ought to know exactly what kind of text content will be lost (if any) and be able to provide some guidance instead of creating this state of FUD.
But in Onshape we don't even get this blanket warning, let alone anything targeted to the particular file that has been imported.
It turns out that my file has hundreds of parts in it which are all in the right places, however each individual component pulls apart when I click and drag it rather than moving as a rigid assembly.  The assembly is missing all the mates.
According to the Help feedback person: "Unfortunately the only system capable of fully reading in SolidWorks' mates is SolidWorks. We're exploring the ability to bring them in properly, but that functionality is a long way off."
Here's the question:  Is it possible for me to put them all back in by hand if I opened the Onshape version next to the Solidworks version and went through the model bit by bit?
It depends.
It depends on (1) how many missing mates there are, (2) whether there are any mates in the model that lack an equivalent in Onshape, and (3) whether there are any other elements in the Solidworks file that I don't know how to find and replicated over by hand.
These are the three issues that I have to contend with in the decision of whether to push forward with fighting for a conversion, or continue to live with the current user on his single Solidworks model no one else can help with.
So here's my ask:
Please can we have a special Help page detailing the risks and challenges for importing from Solidworks files, which includes some tips and tricks as to what to look for and how hard it's going to be?  This page should be linked to from the imported file tab, because that's when it's most relevant.  (Of course, make this documentation for any of the other file types first if it is more dominant in your user stats.)
Secondarily, can we have a technical report on the imported file tab stating what components were found, what didn't get imported, and the levels of approximation made to unsupported entities that did get imported.  Information that helps me to decide whether it's stuff I can deal with, or whether it's not worth it the hassle.  That kind of thing.
Has anyone else been through this process of bringing in a Solidworks model and gave up half way through?  If so, what got in the way?
  • pete_yodispete_yodis OS Professional, Mentor Posts: 666 ✭✭✭
    edited November 2015
    @julian_todd Have you considered exporting the top level Assembly from SolidWorks as something more geometry neutral like parasolid and then importing that into Onshape?  I can't speak to the importation issues you may have with SolidWorks files, but thought it might be helpful to try another way around.
    Did you try importing that into a part studio?  I would consider bringing the top level into a part studio first, and then creating an assembly studio from that part studio next.  In the assembly studio you'll be able to very quickly "connect" a lot of parts together using the group function.  This will save massive time for components that end up with no relative motion between them.  Then you'll be able to focus on the specific mates that involve motion.
    As always, there are lot's of helpful users here on the forums just waiting for a challenge and love to pitch in if needed.  You can explain your specific problem and then can post public examples of solutions to them.  You can also make your document public as a way of asking for help and users can give very focused help.  Or... if it can't be public you can find users you trust and invite them into the design to help you.  While in the design together, you could enter the follow me mode and watch exactly what it is they are doing.  That last part is far better than a white paper if you ask me...
  • dennis_20dennis_20 Member Posts: 87 EDU
    I feel for you.  You won't get the mates to import.  All you'll get are dumb solids.
    I agree with @pete_yodis that something you should try is to export the SWX assembly as a Parasolid.  This should bring the file into Onshape as a single multi-body file with the parts in the same location they were in in SWX.  If they still move around you could perhaps select them all and freeze/fix them in place.
  • mcconnell113mcconnell113 Member Posts: 74 ✭✭
    do you lose all your sketch and feature tree when you import? I've tried exporting to solidworks and it seems like theres no changing things unless i go back and do it in onshape. Are there any tutorials yet for migrating a model either from solidworks to onshape or vise versa?
    John McConnell - Let's change things.
    Saplingstore.com
    @mcconnell113 and @julian_todd ,
    Migrating a model from one CAD system to another only gets you a dumb solid.  The only exception to this is if the destination CAD system has the ability to read and interpret the native file from the originating system.  I am not aware of a mainstream CAD system that can do this with 3D parametric files.  This is just another fact of life of current CAD technology.
    SolidWorks has a utility, FeatureWorks, that assists in running through a dumb solid and converting it into a parametric file, but it requires a considerable amount of interaction.  Unless you were the one to create the file in the first place it is unlikely you'll end up with a parametrically identical file in the new system.  It might be functional, but it won't be the same with the same constraints and design philosophy.
    If someone can develop software to read and interpret a current file from the mainstream CAD systems and recreate it in their CAD system they will have a goldmine.
    I think a simple copy-paste sketch with dimensions from sw to ons would be the first step to ease up recreation.
    To be honest, I don't see it being realistic expectation to Onshape to read native sw files in with history and mates. It would be nice but handling all those versions and following them in future would need a team for this particular task.
    What I have done:
    - with simple parts, import dumb solid create new sketch, grab the shape with use/project tool, extrude new part and delete imported body
    - with complex parts, try to manage with direct editing or make some coffee and recreate during night (consider as exercise =) )
    - with assemblies, use group mate for all static parts (before moving anything) and recreate motion mates
    //rami
