how CAN I IMPORT PART FORM OPENSCAD
New to CAD and OnShape and trying to use for my 3D printer but some models available are made using OpenSCAD and wonder how/if I can import to start using in OnShape directly.
Thank you in advance.
CW
  • EvanReese
    EvanReese Posts: 3,055 PRO
    not sure what OpenSCAD can export, but Onshape can take a number of types. .stp, .x_t would be best.
  • fst
    fst Posts: 79 ✭✭
    You can try to import your OpenSCAD model into the FreeCAD OpenSCAD workbench first. If your design doesn't use hulls or other features that enforce tesselation, then chances are good that you can export it as a STEP file with precise surfaces and then import that into Onshape.
    Otherwise you can export as STL in OpenSCAD right away - this will always be mesh data and thus an approximation for round shapes (so set the tesselation resolution high enough, e.g. with "$fa=1; $fs=0.5;"). This is supported for all OpenSCAD features.
