All lines are blackened but I cannot use the circular tool.
mario_darceuilmario_darceuil Member Posts: 113 ✭✭
I cannot use the circular tool to create multiple boxes as shown even though it appears that all is defined. Please help it is not working.
  • S1monS1mon Member Posts: 3,332 PRO
    You're going to need to share an Onshape document and/or some screenshots. It's very unclear what problem you're trying to describe.
  • mario_darceuilmario_darceuil Member Posts: 113 ✭✭
    I did leave a copy of the document.  Please help S1mon I cannot get the circular tool to give me 12 copies of the rectangle 30 degrees apart. In fact the circular tool is not activating even though all the lines are blackened.
    You can do a circular face pattern, and it works just fine. I would probably do the hole as a separate feature, and then do a feature pattern, but face patterns are actually faster. They just take more effort to redefine.
    Here's the document.
  • tony_henrietony_henrie Member Posts: 4
    If you already closed (confirmed) the sketch, you have to either edit the sketch or open a new sketch to use the tools.
    Maybe you should have linked the file S1mon.
    I would have liked to learn how to properly defined the sketch so that I could use the circular tool myself. I try and follow the image.
    I did link the document. The blue text is the link.
