Extruding Not Working?
chloe_chen866chloe_chen866 Member Posts: 7 EDU
My extrude isn't working, I am sure my sketch is closed.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 6,073 image
    A region is closed if it is shaded.
  • _anton_anton Member, Onshape Employees Posts: 544 image
    edited March 2023
    Is any region (or multiple regions) in the sketch meeting at a single point? Extruding that as a single part would create nonmanifold geometry, which our geometry kernel disallows.
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,801 PRO
    You might have also have some "zero thickness" geometry in there that could be giving you trouble
  • chloe_chen866chloe_chen866 Member Posts: 7 EDU
    If I go out of the extrude mode everything is shaded, so I know it is all closed
    Actually I think I see the problem in the image: you have the extrude set to "intersect" and no "scope". Try setting it to "new" instead...
Howdy, Stranger!
