Exporting Onshape projects as Solidworks Native file types
ryan_mcgoldrickryan_mcgoldrick Member Posts: 71 ✭✭✭
Our company is looking to trial Onshape for 12 months.
Its an expensive trial and at the end if we decide not to proceed are projects are locked up inside of Onshape.
I understand you can export .step and also "native" solidworks files but is there any documentation on what the results look like or that process is really?
It is not a concern of mine but largely of my colelagues and other stakeholders in the business.
Any info and resources that can be shared/linked appreciated.
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,042 PRO
    I never heard in 25 years of "native" exports from one cad system to another, regardless of the system. Its only neutral formats. No history tree. I'd be shocked if there is a "native" export.
  • ryan_mcgoldrickryan_mcgoldrick Member Posts: 71 ✭✭✭
    There is an option to export to solidworks file format from onshape. it won't have a tree but will use feature recognition in Solidworks to attempt to rebuild. Just looking for more specifics and information around this.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,952 image
    Both systems use Parasolid as the kernel so this is the preferred format, since no translation is required. No feature tree obviously and unless you make blocks with holes don’t expect FeatureWorks to produce anything but garbage. Drawings would be DWG format.
  • PattabiPattabi Member Posts: 54 ✭✭
    @ryan_mcgoldrick If you are exporting the CAD files from one software to other it will not carry the feature tree. Just the solid model without feature tree.
    SolidWorks export option means that you get the exported file in .SLDPRT file format, and it doesn't mean it will also export the feature tree.
    You can export all your project files in any format you like, and then you can trigger "Recognizing Imported Body Features" in SolidWorks. Which automatically creates the SolidWorks features for the model.
    If you have any questions let me know.
