How to add global variables to a configuration
john_robinson568john_robinson568 Member Posts: 15
Hi All,
I have a project that contains multiple part studios and assemblies. It also has a variable studio that contains all global variables. I am trying to create a (list) configuration that will set the value of some of those global variables. I've created configurations before, and setting the value of a local (ie in the feature list) variable is easy, but I can't figure out how to set values of global variables. I've tried creating the configuration from a part studio and from an assembly, and I can get it to work either way. Any help much appreciated :)
Cheers, John
  • john_robinson568john_robinson568 Member Posts: 15
    Does anyone have any suggestions on how to do this please?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,988 image
    Global variables are top down only and can’t be configured. You could swap the global variable that you use at a part/assembly level by using an array like so: [#var1, #var2, #var3][2] where the “2” is the selected value and the result would be #var3
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,621 PRO
    @NeilCooke
    The downside with this approach is that you would have to manually propagate the configuration through every assembly/part where it's used, which defeats the purpose of it being "global".
    I understand there are probably some "interesting" ramifications but the ability to configure a variable studio to affect every downstream part/assembly would be really helpful for configurable models!
    Thanks Neil and Eric for the replies, I appreciate your help :)
