Project onto curved surface
thomas_hirsch137thomas_hirsch137 Member Posts: 7
I want to model a watering can. I'd like the outlet to be wider at the base, and join up directly to the surface of the can. Which tools could I use to achieve that.
I tried to use projected surface, but it didn't work, because I cannot sem to use it like sketches, it cannot be selected for extrusions and loft bases for example.
  • robert_scott_jr_robert_scott_jr_ Member Posts: 759 ✭✭✭
    Please post a link to your Public document so we can see how you modeled it. - Scotty
  • EvanReeseEvanReese Member, Mentor Posts: 2,862 PRO
    I don't understand the description. Can you annotate a screenshot or something to draw what you're going for (even badly)?
  • _anton_anton Member, Onshape Employees Posts: 525 image
    Perhaps you're trying to hollow out the spout? It's probably easiest to model it as a separate part, shell it, then union it with the rest of the model.
  • ScalefistScalefist Member Posts: 4 PRO
    If I am understanding correctly, creating a loft for the spout with the desired cross-sections should do the trick.
    I'd likely approach this by modeling the entirety as a solid and use shell to create the internal cavity.
  • thomas_hirsch137thomas_hirsch137 Member Posts: 7
    Thanks for the hints, I did solve it by simply changing the order, to create the shell after attaching the spout, so that it also becomes hollow, and then just boring a hole at the top, using the line between the center points of the circles that make up the spout's loft bases, which is not perfectly correct, but good enough.
    Here is the model.
    https://cad.onshape.com/documents/526ee6854429c1d9a4c0ef8d/w/f5acfba19830a3db266e715c/e/b131e2421d4ec1ed176d9bd0
