very low frame at onshape
i am a solidworks user. my computer has intel hd 3000 graphic card and nvdia card. i only use intel hd 3000 graphic card because nvdia card is faulty.
I uploaded a project that I used in solidworks on my computer to onshape. I feel very, very low fps value in onshape. it is not a complex assembly.
I can move the design fluently in solidworks.
I have tried in different browsers and the problem persists. I don't know if this is the problem or not.
as if the fps value in the browser is between 5-10. the same assembly fps value in solidworks is like 60 fps. it works very fluently.
NeilCooke
Moderator, Onshape Employees Posts: 5,969
As you can see from the check your graphics is very poor. If you press CTRL+D you’ll see the exact FPS you are getting.Senior Director, Technical Services, EMEA0
I didn't know about the ctrl+d command. Thank you very much for this command. After learning this command, when I tested it on windows 10, it gave 5-6 fps. After installing windows 7, it gives 35-30 fps.
