Is it possible to do a broken out section in an isometric view
derek_westwoodderek_westwood Member Posts: 34 ✭✭
Is it possible to do a broken out section in an isometric view? I want to do one in the drawing below in order to show the M6 threaded insert (see area outlined with spline)
https://cad.onshape.com/documents/672fd38dd90c98722cb1677c/w/59f5a13c2709b1bcac98a7b3/e/8cb673da52ec5b609c886a92
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,093 PRO
    It probably is but I don't think I've ever tried that. Maybe someone else will know how. Alternatively, have you considered exploded views? I use them on all my assembly drawings. Usually one to show the parts and any special assembly notes. Then another isometric view to show it fully assembled. Showing the shaded view and making the parts different color also helps clarity. This works great even on black and white printers.
    https://cad.onshape.com/documents/46ba029732b06c5db61aac25/v/7d35ee12b228ad4c52a4f69f/e/35f317e2ef644fa5e8f41dad
  • derek_westwoodderek_westwood Member Posts: 34 ✭✭
    Thanks Nick, I must admit to tunnel vision there, exploded view probably a much better option. Still interested to know if broken out section is possible though! Derek.
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,620 PRO
    @derek_westwood
    Yes, you can do a broken out on an iso view. The trick (which had me confused before...) is that you need to select a reference entity for the "depth" of the broken section on another view!
    Here's a quick and dirty example:
