Creating a sinusoidal cut on a cylinder
daniel_jacob753daniel_jacob753 Member Posts: 4 PRO
Hi there, does anyone know how to make a sinusoidal cut on a cylinder?  First, I made a sketch using defined points and a spline to make a sine wave.
Then I wrapped this around the cylinder.  I was not able to directly cut at this point, so I wrapped as a surface.
Then I tried to cut this.  Created a section as shown here.  Constrained it to be parallel to the central axis.
Then I swept this.  None of the sweep options align with what I need.  If I keep the sketch oriented, I get this...
If I do not orient I get this...
I've been considering creating a second wrapped sinusoidal surface on the ID and then (hopefully) being able to get an accurate solid from a merge of the two.  That will be a good bit of work and not sure I'll get what I want, which is a cut that follows the sine wave on the outside and is perpendicular to the outer cylinder.
Thanks for any help
