IS IT POSSIBLE TO MAKE 4000+ HOLES IN ONSHAPE?
Lightning_sree
Member Posts: 3 EDU
in Drawings
Hey @David_YL_Nguyen
I have tried the pattern function, still can't make the holes.
Thanks for your feedback. Try this link
https://cad.onshape.com/documents/3e704ea1e63fe99bb7cd5bb7/w/06f9f745a50e0627cb74c4d5/e/80ca51dea1ee21b6557133c8?renderMode=0&rightPanel=sheetMetalPanel&uiState=64d39f7374d56116c6ecc44b
Sorry, by mistake I have pressed the answered! But it not solved. For reference" this was pervious discussion created" - https://forum.onshape.com/discussion/21578/is-it-possible-to-make-4000-holes-in-onshape#latest
As mentioned in the other post, you can create a pattern.
This example is tricky due to several issues, and the performance is very poor... But here you have it.
https://cad.onshape.com/documents/7f5e77ce55042b311ac806a0/w/30c47030db01ffabf3aa1f9a/e/2c4ef73d32b53719cdb7b533?renderMode=0&uiState=64d3edcb6fa34e2365ad14ceEduardo Magdalena C2i Change 2 improve ☑ ¿Por qué no organizamos una reunión online?
Partner de PTC - Onshape Averigua a quién conocemos en común
效能比較差,不過最終還是有成功產生
It's a cylinder to cylinder intersect patterned a million times.
I had a customer designing airplanes and wanted to show the revit holes in the airplane's skin. That killed the project. We changed the project strategy and figured out how to make this representation.
If you're playing around, good luck. If it's a real product, change your strategy.
I had another go at this and found that for now the fastest/most manageable solution is to first create a surface and then to turn it into a sheet.
Still requires some processing time but much better performance than the other options I have tried.
https://cad.onshape.com/documents/8b6e901a64436a385b7df091/w/98ea66a8adc5e16925dab4e3/e/5a5ddfcc04b9e29dd2ae1505
Let me know if this helps. Cheers
