Home› General
Laser Measure (New Custom Feature!) 🆕
MichaelPascoeMichaelPascoe Member Posts: 2,754 PRO
edited August 2023 in General
https://cad.onshape.com/documents/11b3c35c86c54ad322793270/w/912fd62e61faa3b3e8c9412e/...
Laser Measure allows you to:
  • Measure a distance based on a direction.
  • Find distances to unkown entities. (Example: last entity in a pattern)
  • Save measure line as a curve for downstream references.
  • Create a variable of the measured distance.
Do you spend hours a day in Onshape? Consider automating your process with custom features and API.
CADSharp specializes in custom features and API.
Laser Measure - Tutorial
https://www.youtube.com/watch?v=OoV_s16p5-A
  • xTimRicexTimRice Member Posts: 61 PRO
    Very neat!
    Handcrafted furniture in Boston
    https://thesmoothcut.com/
  • glen_dewsburyglen_dewsbury Member Posts: 1,257 PRO
    Nice one Michael
  • MichaelPascoeMichaelPascoe Member Posts: 2,754 PRO
    ty B)  It's a pretty specific feature, but I needed something like it the other day. It's mainly intended for variable feature patterns.
    (For anyone who isn't familiar with variable feature patterns, see the video tutorial above for an example.)
  • bryan_lagrangebryan_lagrange Member, User Group Leader Posts: 960 âś­âś­âś­âś­âś­
    @MichaelPascoe This would be cool to demonstrate at an upcoming user group meeting. :)
    Bryan Lagrange
    Twitter: @BryanLAGdesign
  • S1monS1mon Member Posts: 3,880 PRO
    edited August 2023
    @MichaelPascoe
    This looks interesting, but I'm trying to imagine what problems this solves that some of the other measuring Featurescripts can't do? I feel like Konstantin's Measure Value and the now built-in measure to variable functionality have a lot of options to project measurements on to lines or Mate connectors. I've definitely gotten myself into situations where I had to create a helper sketch to get a measurement I needed, so I'm sure there are holes. Without going through all the other tools again myself, can you explain what's special here? Thanks.
    edited August 2023
    @S1mon
    Measure Value is my default for any measuring, even before I use the built in :D. You can pretty much do anything you need with a helper sketch and a normal measuring tool.
    Helper sketches are a pain to work with inside variable feature patterns. The "Keep laser line" option, makes it less of a pain when trying to get measure lines to reference inside the pattern.
    Referencing the last entity in a pattern can be tricky. You can do it with a Sketch, Extrude up to next, and a mate connector; Laser measure can reference it in one step, but it is still shooting from the hip. I could imagine an option in Linear pattern plus by @Evan_Reese: "Create reference point" which would allow the user to select a point to reference from the original entity, this would create a robust point at the same position on the last patterned entity for downstream features to reference. So it wouldn't matter if the quantity of pattern changes, the reference point will still be good.
    @bryan_lagrange, sounds good to me. Custom features are a fun topic.
    Thank you @MichaelPascoe
    Bryan Lagrange
