Spindle Shoulders
A common lathe operation takes the stock from a square cross-section to a round cross-section.  The transition over a short distance leaves an arc on the flat face as the cut slopes into the stock.  My efforts to model the effect in Onshape using Revolve and Loft did not succeed.  Is there a method or Onshape tool useful in the purpose?  Thank you.
