Eliminate facets on a cylinder surface
david_gittens
Member Posts: 4 ✭
in General
The ~100mm dia cylinder designed in Onshape, sliced in Cura, has numerous facets around the circumference when printed on my Ender 3 Neo 3D printer. These facets are visible in Cura, irrespective of the Quality settings, but not in Onshape. They are also visible in the printed part.
Is this an OnShape issue or Cura please? ? If its OnShape, how do I eliminate or at least reduce them please. Thanks in advance
MichaelPascoe
Member Posts: 2,814 PRO
@david_gittens, what do your export settings look like in Onshape?
When exporting your model as an STL, there is an option to change the resolution of your model. Try setting it to "Fine", if that doesn't work, try "Custom" then adjust the settings to fit your requirements.
RENDERCAD
rendercad.ai - Photorealistic product rendering.
________________________________________________________________________3 -
EvanReese
Member, Mentor Posts: 2,867 PRO
I agree with Michael, this is a tessellation quality issue on export.2
RENDERCAD
