Quick Question on Filtering Sketch Entities
james_hulliberger710james_hulliberger710 Member Posts: 5
I sometimes struggle to be able to select a Line, or a Point in a sketch.  Other lines and sketched get in the way.  Is there an option to like hold down a button on the keyboard to only select a certain type of entity?
Like, hold down Shift+S for only select Lines, or ALT+S for only select Points?  It would be handy to be able to filter out other types when making selections, sometimes.
    Right-click "select other" or press the keyboard button above TAB.
    Neil is right. Use the "~" key when mousing over it to "select other". press the key repeatedly till it highlights what you want. I do sometimes miss my entity filters from Solidworks though.
  • james_hulliberger710james_hulliberger710 Member Posts: 5
    Nope, that's not what I am looking for.  I don't want to "select something else..."  I want to prevent the cursor from putting focus on types of entities other than the one the keyboard shortcut specifies.  It would be a keyboard shortcut to say, "Just pick lines", or "Just pick Points".
    Doesn't "other lines get in the way" infer you want to select something else? Anyway, short answer is no, but feel free to create an improvement request in the category on the right ==>
    That was  typo.    I meant to say "Other entities" get in the way.  It's no time and effort savings to cycle through "Other" when all I'm really wanting is for the point not to get in the way when I'm selecting lines.  It's faster to just zoom in a bit to find that bit of line that allows me to pick it.  If the point (or whatever) did not get in the way I could generally happily click click click on the lines I want and not have to zoom or go through the process of "other".  (which is handy for picking something behind or under, I admit.)
    Sorry, I just remember having this option in some other design software (Probably Solidworks, but I can't say for sure, honestly) and found it saved a ton of time and frustration.  I thought it must be ubiquitous to design software to have a keyboard shortcut to filter available entities to pick.
  • S1monS1mon Member Posts: 4,052 PRO
    Other tools definitely have ways to filter for entity type. It can be useful but I could see a more general selection building tool being a bigger bang for the development effort.
