Can I make a Hole through this part
cyrus_costa541cyrus_costa541 Member Posts: 56 EDU
I want to make a hole that starts from on of the red surfaces and ends at the other how can I do this.
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 916 PRO
    edited November 2023
    Sketch a hole profile on one red surface.
    Sketch a point on the other red surface.
    Create a 3D spline between them.
    Sweep remove the profile.
  • cyrus_costa541cyrus_costa541 Member Posts: 56 EDU
    Ya I thought about doing that but the hole needs to be different sizes as you can see cuz the red profiles are sized differently. So is there any way I can make a surface that changes sizes?
    Loft
    Loft.  With a Path.
    I tried that but it says it would create a self intersecting body. What is that and how do I avoid it?
    To avoid self-intersecting bodies, avoid loft paths with tight radius bends.  See the examples below.  The first one works because the path has gentle bends.  The second one self-intersects, meaning the lofted shape runs into itself.
