Appending or combining to qUnions
sean_connor714
sean_connor714 Member Posts: 6 ✭
Is there a way to combine or append to a qUnion? In the code below, if "firstRow" is false, I'd like to add an additional subtract target to the boolean operation at the bottom. I've tried doing a qUnion of a qUnion and a qCreatedBy, but that doesn't seem to work either.
                var subtractTargets = qUnion([
                        qCreatedBy(id + i + "trussPoint", EntityType.BODY),
                        qCreatedBy(id + i + "slotForward", EntityType.BODY)
                if (firstRow == false)
                    var previousPlane = plane(trussPoint * meter, -previousPlaneComponents.normal);
                    opExtrude(context, id + i + "slotBack", {
                        "entities" : definition.slot,
                        "direction" : evOwnerSketchPlane(context, {"entity" : definition.slot}).normal,
                        "endBound" : BoundingType.BLIND,
                        "endDepth" : definition.bodyRadius
                    opTransform(context, id + i + "transformSlotBack", {
                        "bodies" : qUnion([
                            qCreatedBy(id + i + "slotBack", EntityType.BODY),
                        "transform" : transform(evOwnerSketchPlane(context, {"entity" : definition.slot}), previousPlane)
                    subtractTargets = qUnion([subtractTargets, qCreatedBy(id + i + "slotBack", EntityType.BODY)]);
                println(subtractTargets);
                opBoolean(context, id + i + "subtract", {
                    "tools" : qCreatedBy(id + i + "slotInterior", EntityType.BODY),
                    "targets" : subtractTargets,
                    "keepTools" : true,
                    "operationType" : BooleanOperationType.SUBTRACTION
Thanks,
    NeilCooke Moderator, Onshape Employees Posts: 6,100 image
    edited December 2023
    That should work, but it's better to create an array of queries then qUnion the array at the end. Also, you don't need the qUnion in the opTransform.
    var subtractTargets = [
    subtractTargets = append(subtractTargets, qCreatedBy(id + i + "slotBack", EntityType.BODY));
    "targets" : qUnion(subtractTargets);
  • _anton
    _anton Member, Onshape Employees Posts: 550 image
    Syntax looks right; I'd recommend using debug(context, myQuery) to make sure you're actually getting the expected queries. In what sense is it not working?
    (Protip: qUnion has overloads for 2, 3, and 4 queries, so you don't need to enclose them in an array in those cases.)
