feature request: exporter UI improvements
CaptainBisquickCaptainBisquick OS Professional Posts: 33 ✭✭
I guess it used to be that STL was the default export format, and now it's parasolid. It would be nice if OnShape would set a cookie and remember which format I use (or the one used most often, if more than one). In my case, I only ever use one.
Or even better, would be a streamlined export process. For example, if each part could be assigned an export destination, file name, and format, then I could simply click an export button on the part (in the part studio) and be done with it.
    Instead of cookie I would like to see these things built into account - so that you have exactly same experience no matter where you sign in..
    //rami
