How to draw a hollow center ball
in General
Im new. can anyone help me over the phone and walk me through how to make a file of a Round ball:
7" round ball that is hollow in the center. two inches thick from the outside to the inside surface. The interior void is 3 inches in diameter. The ball would be 3d printed out of foam rubber and have 1.250 holes all the way around the sphere spaced equally from each other approximately .500. I need an STL file so that this prototype can be 3D printed. It needs to be made of foam rubber so that it can be squeezed into a 3 inch ball, then immediately expand to 7 inches.
https://forum.onshape.com/discussion/comment/12764/#Comment_12764
which shows how to create hole patterns, but the difficulty is in the geometry of spacing the holes evenly over an entire sphere.
See https://cad.onshape.com/documents/91de9126f0c24d81b35d8a26/w/3f74fa95326b4236873250a5/e/aded0bf282664b24b717c822
Sketch 1 was simply rotated around the vertical axis through the centre.
As you can see, I am now trying to work out how to equip it with a handle but that's another issue.
